hi sir/ma'am,
i bought speria xa dual mobile. whenever i use mobile camera phone getting heat. many times phone gives warnning of over heating. i think this mobile is defected. once i visited sony center they said we cannot do anything. what should i do.
Hi @shanJI,
It is completely normal that the camera app warns you that the device is starting to heat up after using the camera for a long period of time or after the use of a different app which is heavy on resources. If you want, you can choose to not show the message when it appears by ticking the box shown in the bottom left of the notification.
If I understood you correctly, it simply warns about overheating and doesn't actually close the app?
sony xperia xa ultra heats up when camera is turned on.pls help
This is normal, expect a moderate heat in your phone while the camera is up and running, and even more heat if you are recording a video for a long time. Your phone will shut down the camera application if the temperature exceeds the safety threshold.
If you think that the phone heats really fast, like after taking one or two still pictures, try to clear the cache of your camera app:
- Go to Settings -> Apps -> Camera -> Force stop, Clear data and restart your phone.
If this doesn't help, consider performing a backup of your important data then a software repair using Xperia Companion.
If all of the above doesn't help, you may need to contact your Local support and get your phone inspected by a professional.
Sony xperia xa ultra camera take after coming heat
it's ok, it will heat. but how you check product quality by comapiring with others. it heats too much than expected. heat may damage sensors and any other hardware brutally. if a low quality product performing better than sony mobile. what i supposed to sony use wrost quality of hardware.
