Wifi and bluetooth connectivity problems
ALargeCat
So this issue has been going on for a bit with the wifi but both problems are similar.
For Wifi it'll report that it has perfect signal but won't be capable of sending or recieving data. This will persist untill I reboot the phone.
Then after taking the recent update (build 40.0.A.162 with November 6 security patch) the bluetooth has been refusing to connect unless I reboot the phone. This occurs with my Mazda, and my Sena 10c headset.
29 REPLIES 29
Mawei1
Exact same. Wifi useless and blutooth not connecting to my car or speaker at home for last couple of weeks unless I restart phone every time.
Trebor11
There's a 6 page thread on this already. My phone doing same. Trying to get Vodafone to swap. They can't find anything wrong... Grrrr
kazzed
I am also having these issues.  Bluetooth won't connect, and wifi will basically disconnect, even though it is showing that it is connected.  No amount of attempting to reconnect will work until I restart the phone.  It will work for a little while and then it starts all over again.
pawelb1
You do not have to restart your phone ... just turn on and off the airplane mode
Trebor11
By jeaves that's done the trick!!
mathieu76
After TWO replacement from my service provider, the 3 different devices of XA1 still have the same problems!!... I don't know what to say... Look like every XA1 devices in the world has the same problem... Is someone knows if it's an hardware of software issue ??
Yankfork
I will try that. Very maddening . Not a great advt for Sony
Bounty84
Also same Problem (Germany). Any solutions? Think I will wait for Android Oreo.
Yankfork
Tks.  I notice the problem is much worse when battery level drops below 50% charged and the there is no solution ezcept to charge fully.
