Usb Otg problem
DhruvNimavat
Usb Otg problem
Xperia xa dual f3116 updated to latest version.
One usb pendrive (hp) works fine with otg cable.
Other pendrive with same format (moserbaer) dont show up.
Other problem is when i connect my HP pendrive it shows in "es file explorer" but doesn't in storage.
There is only two internal and sd card. Then where is my pendrive?
Also reading data in that usb is fine but cant copy anydata from pendrive. It gives error for not permitted.
14 REPLIES 14
sayan
Im having the same problem with my Xperia XA Dual. My Phone is up to dated. How to fix this ?
Pars987
OTG function is not stable in large file moving esp in cuting files to SD card , for example comletely disconnecting occures by device in this siuations (XA dual)
Pars987
How heavy are the files?
Pars987
uliwooly
3.73 GB of files + 5GB movies
well, that makes sense
mahar
i am using sony xperia xa dual last 2 months, i have problem with it that when i use OTG cable phone shows nothing.
please help me how to use external usb via OTG. is xa dual is compatibal with usb host?
Pars987
Hi. XA dual supports OTG . maybe you use NTFS format on flash drive or HDD, So install (ES file explorer) in Google Play to access NTFS too
mahar
I use ES file Explorer but problem same..
Now what should do? Plz
mahar
When I use usb via OTG cable Explorer does not show any external device. If there is any way plz tel me
