When i blog my handsfree into my phone and trying to raise the volume up it shows my "your ui system has stopped"
I want to know what is wrong with this new phone!! ๐๐ฉ
Hi @SAndyy6, welcome to our community and I'm sorry to hear about this.
If this only occurs when you are raising the volume in your phone, make sure that the System UI application is allowed to draw over other applications in your phone.
You can turn this on if you go to Settings > Apps > cogwheel in the top right corner > Draw over other apps > 3 dots in the top right corner > "Show system", scroll down and find "System UI" and make sure that it's allowed to draw over other apps.
Once you have allowed this, try raising the volume again and see if you still receive the same error message!
Let me know if that helps!
Thanks so much for your help this happened to me and I have no clue what to do
Omg thank you so much this had been happening to me for over a year
@ultranova @Mumbo100, You both are very welcome, just glad I was able to help!
Let me know if there is anything else!
Thank you Jonas! It really helped me cause I had the same problem.
