Every few minute the system freeze and a message appear (system is not responding. :close app or wait)
Restarting the phone doesn't solve the problem
What can I do?
Hi @Sony000,
I'm sorry to hear this. As @najodleglejszy suggested you should try to reboot your device to safe mode and see if you are still experiencing the same behavior.
I would also recommend that you temporarily remove any SD card you may have in your device to see if it may be causing this behavior. If there is no change I recommend that you perform a software repair using Xperia Companion.
Keep us posted on how it goes.
