I have Sony Xperia XA ultra. Music automatically plays next song continuously.. It's not even playing a song for a sec.. Fm is also not working..
Hi @MeenuMohan, welcome to the community.
Try resetting the Music app. To do this please go to Settings > Apps > Music > Force Stop > Storage > Clear Data. Then restart the app.
For the radio, make sure you have headphones connected as it needs them to act as the antenna.
It worked!! Thank you so much!
Same problem persists again!
Yeah.. It ll work just fine if I reset it.. After an hour or so it is not playing..
It may be due to one of the apps you have installed. Try just testing it in safe mode for a few hours and see if it happens.
Just turn off your stamina mode dude that will fix the issues
I had the same problem with my sons xa dual
I tried your suggestion and now all my music aside from the last few I added are gone, can't even find them on my memory card
