Xperia XA Ultra, after updating software 36.0.B.2.109 minimum Brightness level very high. In old version level is good.
Go to color control secton in Settings --> Display
The default value of RGB is (255, 255, 255)
Reduce the RGB value to (0,0,0)
now U'll get the lower brightness..
RGB (Red, Green, Blue)
I hope this will help you ...
Hello,
Got an Xperia XA back in November 2016.
Issue: Brightness is not Bright enough. Sometimes it gets enough brightness but when I lock the screen and unlock, it goes back to a lower level of brightness. I have to either go to the brightness slide and keep sliding it back and forth from Min to Max and hope the brightness level kicks in. In the dark, its readable at max brightness but useless in the daylight even at max bright.
This happens even in Safe Mode. I've gone back to the store and they have advised to send it in for repair which means i lose the phone for 1-2weeks.
This happens even after resetting the phone.
Help: I'm trying to find out if this is something that can be fixed on my own.
Adaptive Brightness: Off
Smart Backlight Control: Off
Image EnhancementL Super-vivid mode
White Balance: R=0, G=0, B=0
Build Number: 33.2.A.2.73
You could repair the phone with XC but it'll be wise to follow their suggestion and get it inspected by your Local support
@uliwooly
whats XC?
Ah. i actually did that. thats what i meant by the reset the phone. sorry if i wasnt clear earlier ;(
have the same issue can't adjust brightness at low level 0-50% of slider is not changing brightness of the screen at all only 51-100% part of slider can be adjust
the screen is to bright even in lowest settings. they not thinking about people and there eyes the only way is to get it lower is a blue light filter app
