Xperia XA Ultra, after updating software 36.0.B.2.109 minimum Brightness level very high. In old version level is good.
After the update my minimum brightness level is increased, please get it fixed at the earliest, much irritated with this update.
I am having the same concern with the brightness level on firmware 36.0.A.2.109. It seems that the backlight does not dim properly compared to past Sony Xperia phones. It is fairly bright at 51-100% but between 1-50% it almost has no change. It's as if the screen chooses to stay static at 50% and reducing it makes almost a 5% difference. At night this can become intolerable since it's so bright! It also makes the battery drain faster if I can't reduce the brightness level further. It also doesn't make any difference if it's in automatic or manual mode.
