How long does it take for the xa1 to recharge from at least 20 to 100?
it depends if you are using the phone, WiFi on, or other background apps/services running.
Hi @Bennybunbun, welcome to our forum!
As @uliwooly mentioned, it depends on if you use your device during charge and how you use it during charge or if the device is charged using a USB port or a wall socket.
The specifications that is available in the Environmental declaration is that it takes 2 hours and 45 minutes to charge the device from 0% to 100% when it's powered off and it's charged by using the wall mounted charger and the cable that was included together with the device.
I hope that helps!
