Battery Charging Status on XA2
cobbler
The XA2, when it gets to 100%, does your XA2 say full or fully charged?
On mine it says Charging even though its reached 100%
Tags (1)
21 REPLIES 21
Jonathan2396
hmm need to check but after go to 100% the green led stop
cobbler
Do you mean the light to the far right that is orange when battery is low then turns green when it reaches 90%? or are you referring to the long light in the top centre of the phone directly above the SONY branding?
cobbler
Can you check your battery status after your phone reaches 100% and tell me if it says the words Fully charged?
cobbler
Xperia XA2, is the green led light on the top right hand side meant to go off when the phone reaches 100%?
Jonathan2396
Nope sorry, today i wake up and the led still green
cobbler
Same as mine then, this means that if you were to check in on the battery status in the morning it'll probably still say charging.
You'd think it would say Fully Charged, but it doesn't.
Jonathan2396
Im sorry i was so asleep! tomorrow im gonna see it and take a pic if i could
cobbler
Sometimes like this morning after setting it to charge with the cable to the ac socket I get this instead of it saying just charging. _20180421_101602.JPG
Like I say once it gets to 100 % it just reverts to saying charging and the green charging light stays on the is this normal?
Jonathan2396
This is what I get when the phone goes to 100% a "charged" but the led still green until I unplug and on every other site where I see the battery still say charging
