Around 13applications are showing updates available. But while going fir update they are showing error506code. What should I do now?
I can confirm that latest version 36.1.A.1.86 fixed that problem for me.
Hi there,
I can confirm that I am with OP on this.
I own the Dual XA Ultra with a Sandisk 32gb SD card and ANY apps can't update when they are located on my SD card. I've been formating it within the phone several times but it didn't change a thing.
The only workaround I've found was to move EACH app on my internal storage, update them and then, put it back on my SD card.
It is time consuming and very frustrating since the lastest update.
Have you tried the latest update? I own the dual sim version as well and after updating a couple of days ago, i'm able again to update apps that are moved to sd. I don't know if it's due the update itself or maybe cause it cleared the cache during the installation or something like that, but it does work ok now for me.
Thanks for the idea but my phone tells me that i actually am running on the lastest update.
I did cleared several times my cache to see if it would work but it failed.
I've even tried another SD card, which was a Samsung EVO II 64gb, but even with this, the issue seems more persistent.
Hmm i see. When was the last time you had an update? The update is about roughly 1 week old so maybe it might be soon available in your country in case you haven't updated already yet. Other than that, sorry mate i got nothing.
Last time i had an update was when the phone turned on 7.0 OS.
If you're telling me that you had one just a week ago, mine should be around the corner.
Ill update my case as soon as the update kicks in!
