Xperia x wont turn on
Corina
El celular de apagó de la nada y sólo prendio una luz roja al lado del parlante,que Ya no prende.
No entiendo que paso. Ya no prende más
The cell phone went out of nowhere and only lights a red light next to the speaker, which no longer turns on.
I do not understand what happened. It no longer lights
GT
Marcos11
Trata dejarlo cargando un par de horas y después intentar prenderlo con el botón de power y volumen + al mismo tiempo. Saludos y espero reviva tu xperia.
Try to leave it charging a couple of hours and then try to turn it on with the power button and volume + at the same time. Greetings and I hope you relive your xperia.
GT
10 REPLIES 10
Marcos11
GT
Corina
Mucha gracias ,voy a intentar hacer eso.espero que prenda.
Thank you very much, I will try to do that.
GT
profile.country.NL.title
Strampke
The cell phone went out of nowhere and only lit a red light next to the speaker, which no longer turns on.
Sony as well as the moderaters will appreciate it very much if you use this tool to translate your questions and answers.
Mucha gracias
Sobia83
I have been trying since yesterday to charge my phone. My battery was about 7% I put it on charge and left it. Came back to check the phone it had a red light flashing in the speaker and the phone would not turn on. I have tried to press th on/off button with the volume up + key to force shut down anything nothing happened. I put it on charge again for a number of hours only a red light flashing in the speaker and not charging. I tried Sony Companion to see if it lets me get into my phone so that I can back up my data thats not working aswell. I have had nothing but trouble with this phone. Anyone can help or advise???
Strampke
I have found this in the manual:
Battery notification light status
Green
Battery is charging, charge level is greater than 90%
Orange
Battery is charging, charge level is 15-90%
Red
Battery is charging, charge level is less than 15%
The fact that the led is blinking could point to a loose connection.
It is a known problem from Xperia X that the fit of the USB port can be broken.
Try to manipulate the USB cord carefully to try if you can get the red led to light constantly.
If so you have found the problem.
Youtube: repair or fix.
Sobia83
Hi I have tried this.
The USB port is not damaged or broken in any form of way. I put the phone back on charge and this time no red light flashing and no charging sign at all.
Any other solution?
Strampke
No light, no contact.
Try same cord on other phone and try other cord on your phone.
If it is OK on other phone then the connector in your phone is broken.
Take up contact with local Sony support.
Mervs
Sobia83
Hi there have you manage to solve your problem because my sister has the same problem she got 40% battery life when her phone turns the sudden off, I already suggest the power button and +/- volume but she says nothing is working, hope we can help each other.. Good day👍🏻
Joeboy4u
thanks lovely suggestion. I was so worried
