Wi-Fi problems after lasteast update 47.1.a.12.119(not fixed)
Cristiancc45
No se PORQUE se desconecta del wifi estoy en la versión 8.0
I do not know WHY it disconnects from the wifi I'm in version 8.0
GT
6 REPLIES 6
profile.country.NL.title
Strampke
You're shure you have a Xperia X F5121?
schetz
If I've found the correct one, it should be XZ Premium.
@Cristiancc45would you mind posting the question in correct subforum, here
Cristiancc45
Si mi modelo es F5121
You model me F5121
GT
Strampke
@Cristiancc45
You would do everybody a favor by translating your questions/remarks in Google translate.
As @schetz mentioned, the software you mention is on XZ Premium
Just to check:
When you go to settings and scroll all the way to the bottom you will see Support.
Tap on that and you will see the support screen.
On the bottom of the screen tap in the i from information
You will see the Xperia model
When you tap on the blue Android 8.0.0 you will get the software information
When you tap on the release notes you will see even more information.
I am really curious how you can match your software version with F5121 model.
Let us know please (in English please)
Saranari
Translation via Google Translate:
Wi-Fi does not work for me, it does not connect, but the phone works fine when you check
A mi no me funciona el wifi, no conecta  pero el tel funciona bien cuando haces la comprobación
Strampke
@Saranariwould you mind using translate.google.com please.
