Varför har jag 3 nr som skickas direkt till vidarenoppling hittar inte hur jag tar bort det
Why do I have 3 numbers sent directly to diverting do not find how to delete it
-GT
You're asking a question and you would like to receive an answer.
Here are some tips to get your question answered.
- This is an international forum which uses the English language for communication. Please ask your question in English.
- You can translate your question to English by using translate.google.com
- Ask your question clearly and explain your situation on a few lines.
- Asking questions in shorthand will not result in a good answer.
- Do NOT ask questions like:
- no sound
- bad wifi
- no bluetooth connection
There are a lot of visitors here on this forum who are willing to help you.
Help them by asking your question in a way that describes your problem clearly and write in English.
Sounds like the question might have to do with numbers that have been (unintentionally) blocked?
Contacts -> (menu) Settings -> Block Numbers
Remove numbers that you do not wish to have blocked (diverted).
Låter som att frågan kan ha att göra med nummer som blivit oavsiktligt blockerade?
Kontakter -> (meny) Inställningar -> Blocknummer
Ta bort nummer som du inte vill ha blockerat (vidarekopplat).
