Status bar icon shows only 2 bars even in 1 meter range and gets lost if i move my device away only about 2 meter or less only.
Please any one can confirm this in oreo update or is it just me?
Anyone???
I have a single SIM version but have not noticed any such problem.
The fact that no-one has commented or started other posts would suggest that it's not widespread.
Have you tried safe mode?
Run a diagnostic / system check in settings?
Possibly worth a back-up, reset / Companion repair and restore.
Also,those bars don't mean much.
I've seen those dancing around while still having a normal connection.
Try to run something like https://play.google.com/store/apps/details?id=com.vrem.wifianalyzer&hl=en
This one should tell you more.
Yes I did factory reset +pc companion repair at the time when I saw it hoping it would be just an update problem.
And yes I did check with safe mode, system diagnostic. Same issue everywhere. Please check below situations.
Should I be worried now?check above post.The wifi is useless for me sometime.
THe point is all other device even my neighbour can connect to my wifi from his house but i can't from just about 10 meters away.And all other devices I triedmyself ( MOTO G5 plus,Redmi 5a) don't have this weird situation.
And I did not have this problem before .
A NOTE: The screen was replaced and it was upgraded to OREO when i gave my Xperia X to service centre back in february.When I gave my phone it was running on Nougat and when I got back it was upgraded to OREO.Any hint?or solutions .
It seems that it's time to call for help from Xperia Support.
I did submitted my phone and they are solving it with software repair;which i did like 3 times!
Let's see what happens!
Maybe they will have a look at your phone before returning it to you.
Hope you described your problems in a way that it becomes clear to them, which can be translated as that they do not just do a factory reset but will have a proper look at your device to check if everything functions as it should before returning it to you.
After all it is just a (phone) repair company which not only Sony, but also Samsung, Huawei, HTC and others contracted to do repair jobs at the lowest price.
How I know?
My LG was repaired a few years ago by the same company that repaired my Z3 Compact.
