After last updating, when comes text message in my phone theres no sound. Everything good with calls, messenger and etc sounds,so what I should do?
What if you clear the app data
settings > apps > app info > select the app > storage > clear data > restart the phone
Xperia x
Yes, working, I even did test. I gave every sounds, but not when comes sms
are you getting notifications from other apps?
are you using the preloaded messaging app?
open the app > menu > settings > notifications > change the ringtone
The answer is yes for both your questions. And I had changed the rigtone and it didin't work
Now I'm in safe mode, and it still doesin't work. 😕
