System UI stops working
Yesenia19
Hola, mi celular marca iu de sistema no responde, después se traba y tengo que reiniciarlo varias veces para poder tener acceso.
Hello, my cell phone brand system iu does not respond, then it gets stuck and I have to restart it several times to be able to access it.
gt
profile.country.NL.title
Strampke
First option is to start in safe mode.
  • Switch off your device
  • Power on your device
  • Then press vol-down untill the phone vibrates
  • You'will land in safe mode
  • To return to normal mode just restart your device
If this behaviour does not occur in safe mode then probably an app in normal mode is causing trouble.
