Hello! Where to turn on the audio notification of the full charge in Android 8.0 on my Xperia X Performance Dual?
Hi @Muzontnt1, welcome to our forum and I apoligize for the late reply to your post regarding the "play sound when battery is full" setting in Android 8.0.
You might experience that there is no sound notification when the battery is fully charged after updating to Android 8.0 (Oreo). This is an unexpected behaviour that will be corrected in a later software release.
Note! Software updates are released at different times depending on the operator, market, region or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device. In addition, network operators and specific markets may choose not to use the updates for specific models.
Affected software version
@Muzontnt1 as far as I know there's no such setting, but I'll request some more information about it.
Before I updated to Android 8, i had this setting turned on somewhere in the accessibility settings. Now I'm looking for it in there and I can't find the exact setting. But it still works, still playing a notification sound whenever the battery is full. Though i cant find anymore the setting but im sure it's still there
Hi @JPDRS, you're correct! You could find this settings in Settings > Accessibility prior to the Android 8.0 update.
If you take a look at my previous answer, this is a known behaviour and the setting to enable/disable the sound when the battery is fully charged will be corrected in a later software release.
I hope that answers your question and have a nice day!
