My Xperia X turn off unexpectedly and doesn't turn on until I plugged in charger
HJ01
I am facing a problem with my Xperia X, it turns off unexpectedly without showing any notification. Doesn't turn on until I plugg in charger. There is no issue of battery draining. I did remedies like software reset and repair through Xperia Companion but after I update the applications after reset, same problem continues. Can anyone please help me
Tags (2)
profile.country.NL.title
Strampke
Sounds like some hardware problem after what you are describing.
On the other hand, apps can misbehave.
- did you try to have your device in safe mode and did it happen in safe mode too?
- did you try out the behaviour after just installing the most necessary and commonly used apps?
