my phone does not connect to the pc
Aliasd2
coloco o celular para transferir arquivor no pc mais nao conecar ja troquei de cabo mais naa resolve , ja tentei no desenvolvedor na depuração mais tambem não resolve
I put the cell phone to transfer file on the pc but not connect already I changed cable more naa solve, already tried in the developer in the debugging more also does not solve
-GT
schetz
A duplicate of this one /t5/Xperia-X/Connect-to-the-computer/m-p/1308582#M6135
Anyhow, as Nathan Horner mentioned, this is an English only forum, so you might use Google translate to overcome any difficulties.
To repeat Nathan's questions :
Have you tried another USB port ? Which OS do you run on your PC ? Do you have all drivers installed ? I see you tried another cable. (Você tentou outra porta USB? Qual o sistema operacional que você executa no seu PC? Você possui todos os drivers instalados? Vejo que você tentou outro cabo. )
This is just to help a bit, but please use Google translate, you'll get more help that way. (Isso é apenas para ajudar um pouco, mas use o Google translate, você obterá mais ajuda dessa forma.)
