incoming calls
Yvonne68
incoming calls
WHEN i receive an Incoming call i have to run to my phone,because within 5 sec The ringing stops and i get a missed call message...Never had this issue before
Jonas
Hi @Yvonne68, sorry to hear about this!
As other users have already pointed out, it does sound like you will need to get in touch with your service provider/operator and ask them to edit the time before a call goes to the voicemail, I think I have around 30 seconds, which is plenty of time for me to be able to grab the phone and answer the call!
Let us know how it goes! Slightly_smiling_Face
9 REPLIES 9
nathanhorner
Do you use Xperia Answering Machine? If so, what length do you have it set to? 13s is default I think...
Yvonne68
Answering machine is of.....Voice mail is in though...But cant find The lenght ...
nathanhorner
Possible that it is through your service provider settings. Have you checked there?
Yvonne68
Where do i find my service provider settings πŸ˜‚
@Yvonne68
Open the phone app > menu > settings
Yvonne68
Lol...Cant find service provider settings πŸ˜‚πŸ˜‚πŸ˜‚
nathanhorner
You know when you call your voicemail it gives you options? Check those out.  If not your service provider or operator should be able to help.
schetz
There is also a possibility that SIM card is messed up a bit.
I would definitely get a new one and test. Can't hurt.
I'd do that, in case same SIM works in another phone. Just to narrow down the cause.
Jonas
