Hi how can i block someone 's txt message
Gd36
4 REPLIES 4
@Gd36
You need to download an app for that.
Jake-SonyXperia
Hi @Gd36,
Welcome to the community,
I can confirm that this can be done however, you need to be on android 7.0 and above. See the instructions below.
To block a certain number
  1. Find and tap Phone.
  2. Find and tap the menu button (three vertical dots) > Settings > Block numbers > ADD A NUMBER.
  3. Enter the phone number you want to block calls and texts from, then tap BLOCK
This can also be done within the messaging and Contacts application within there settings.
Let me know if this helps.
shotfirer
Open the message from the person you want to block. Go to three dots menu (upper right corner) – select "Block number".
vijayanand
you can use truecaller it will block the unwanted calls and sms
