GPS signal dropouts while navigating
Philip0
My Xperia is losing GPS connection on the road causing me to take the wrong turn or miss turns.
The handset sometimes has perfect gps signal and has passed the GPS diagnostic test, but has also failed.
My carrier asked me to get in contact with Sony to ensure the service works as provided by them.
Thanks
Tags (1)
Didrik
Enthusiast
Hi @Philip0,
I'm sorry to hear that. Slightly_frowning_Face
There are a couple of things you can try however.
First of all you can try to purge assistance data. Open the dialer and enter *#*#7378423#*#* (*#*#service#*#*) followed by pressing Service tests > GPS > Tap Purge assistance data and reboot your phone. Then check if there's any change.
Considering that the phone fails the test it's not impossible that there is something wrong with the GPS in your phone. In order to rule that out I'd recommend that you also test another app to see if you can find your position then. I would also suggest that you see if there is any change if you reboot your phone to safe mode.
Let me know how it goes!
5 REPLIES 5
@Philip0
That's how you get in contact with Sony >>> Local support
Didrik
Enthusiast
Hi @Philip0,
Philip0
Looks like that fixed it thankyou, also reset my keyboard
Didrik
Enthusiast
Glad to hear it @Philip0, thanks for the update!
Let me know if anything happens.
thmir
Hi Didrik,
I have the same GPS problem wit my XZ1.
I tried the above steps, but only restarting the device works.
After I restart the phone, the GPS works for 2-3 day, then the GPS stops again.
Is there any other solution to solve this?
Thanks
