I'm having the same problem and neither of the options you put up work??????
The first version does not work.
The second one works and it's easy:
1) open the phone app
2) click on a call in the list
3) choose call details
4) click the trash can icon in the upper right corner
Done.
I cannot choose which calls to delete from the call history. Why do I have to delete all the files?
Go to call log, tap on a specific call, tap on the i icon, then the trash bin.
I have the same problem..!
I can't find any i icon
It works!! Thanks a lot!
thanks for the tip.
much appreciated
I have the same problem. I have android 7.1.1. In call history there is several sheets ( all calls, incoming calls, missed calls..). Here I have only one choice (from the main menu - 3 dots in the right up corner) I can only delete all call history.
When I tap on the contact from call history contact details menu appears with detailed information about cantact, then bellow call and mesagges history... From this history calls menu I am able only (tap on detailed calls) make a new call to this contact. There is no i icon and no trash icon - doesnt matter if I long press the detailed call or not.
What I do in wrong way?
Single call I am able to remove only with 3-rd party application (CC Cleaner) after cleaning proccess analyze - remove call history - there is option to set checkbox to selected calls...
