Another "Oreo Update Problem"
Rave2Rave
To Sony support:
The "GPS icon always on" bug known from the xz1 compact is also affecting the x compact, the battery seems to drain a little bit faster, and the USB mode is always set to "charging only" by default, causing Android auto to stop working automatically on the first time plugging in. I always have to plug out and plug in a second time or to manually switch to "data transfer mode".
Besides that I miss some cool features that have been dumped for some reason after the update: the "do not disturb" mode could be set to "only till next alarm". Now I have to manually switch it off after the alarm.
And setting the alarm isn't that comfortable anymore than it had before.
Please stick to the old behaviors on the 2 mentioned points and fix the mentioned bugs. Thank you
reikar
* GPS Icon problem should only be cosmetical. It's not affecting my battery life. They promised a fix soon with some next software update. I disabled GPS icon under Settings->Display->System Icons.>Location. This way you won't see this icon popping out.
* I agree that previous version alarm setting was more comfortable, but since it's android, you can always find some good alternative to use.
* "Do not disturb until next alarm" is still present. On my picture, 3rd option at 7:30
3 REPLIES 3
reikar
Rave2Rave
I don't have that menu anymore since the update...
Rave2Rave
Edit: sorry, found it 🙂
