WH1000 XM5 - after each received call, the music is no longer heard in the headphones
profile.country.RO.title
IonutDumitru
New
I can give an example, I'm listening to music and I receive a call, I answer the call, everything is ok, but after the call ends, the music is no longer heard, even though it seems to be working.
If I receive a call, it works, it's as if the media play was set to zero volume.
I tried disconnecting the headphones from Bluetooth, reconnecting them, the music appears to be working but nothing is heard in the headphones. The volume seems to be ok, it is not on mute. but the music is not heard at all in the headphones. If I disconnect the headphones it is heard in the phone speaker. when I connect the headphones it seems to be at zero volume.
I tried deleting the app, reinstalling it, deleting the pairing with the headphones, exactly the same situation. The only solution I've found so far is restarting the phone.
This thing just started recently, a few weeks ago, before that everything was fine.
Has anyone experienced anything similar? I'm trying to figure out if it's something in the phone settings or something in the headphones settings.
Thank you!
2 REPLIES 2
TheGOAT
Community Team
Hi @IonutDumitru You can try resetting and initializing the headset it might fox the issue:
- Resetting the headset: https://helpguide.sony.net/mdr/wh1000xm5/v1/en/contents/TP1000541012.html
- Initializing the headset to restore factory settings: https://helpguide.sony.net/mdr/wh1000xm5/v1/en/contents/TP1000541013.html
Tom.J.H
New
I have similar with xm4… it occurs when the headphones are paired with two devices. I can be playing sound off my phone “device 2”, then go out of the app (e.g. IG). Later when I return to the app no sound plays in the headphones. In Sony Sound Connect app, a speaker icon shows next to my laptop (“device 1”), even though it has been “asleep” the whole time. I think I remember an incoming call doing the same thing (like you), but I haven’t retested that recently.  My solution was to disconnect device 1, the laptop, in Sound Connect.
