Touchpad driver problem
GotenSSj
I have two little problem with the touchpad of the FS315H
1) I don't manage to disable the pad when using the usb mouse
2) After a format (for dual booting) i cant install the driver, none of the exe in the "pointer" directory work 😞
3 REPLIES 3
rich912
Hi GotenSSj and welcome to Club Vaio.
1. The touchpad can be disabled with Sony Notebook Setup – Start > All Programs > Sony Notebook Setup.
2. Check that Device Manager (under mice and other pointing devices) is listing a PS/2 pointing device and not a PS/2 mouse. If the latter then right click on this and select uninstall, re-boot and let windows discover and install the correct drivers for the touchpad.
Go n-éirí an bóthar leat
GotenSSj
perfect :grin:
thanks a lot :grin: :hugging:
now i have only a minor issue:
the memory stick device icon is wrong, i can survive with this :wink:
rich912
You're welome :slight_smile:
