Doe's anyone know if there is an memory upgrade for my VGC-VA1?
On the web it looks like you can take the computer up to 2GB of RAM.
There are only two memory slots, so I'm assuming that one can replace the two 512MB Modules with two 1 gig Modules.
TD4
Not bad if there rightRich77
Just as a follow up.
FYI I've upgraded the RAM in my VGC VA1 to 2Gb using Crucial Memorys recommended RAM as detailed in their email to me (see copy of email in my earlier post).
:smileygrin: 3 days and no problems, so I think it's safe to say that RAM from Crucial or similar spec can be used to upgrade the memory to 2 Gb.
Hope this helps
TD4
Thanks TD4 that is a help, i will look in to upgadeinng my VA1.
Hows your systum are you runing XP OR VISTA?
have got a v1 and only has 2 slots for 2x 512mb only pc2700 best bet not too fast for the board stripped mine out last week to install more ram quite easy when u know where all the screws are regards
lee
Rich77
Running XP at the moment. Will upgrade to Vista when Sony release drivers.
TD4
TD4
Is your VA1 running fine after you upgraded the ram, Thanks,
Rich77
Almost 2 weeks and I've had no problems after the memory upgrade :smileygrin:
TD4
Hi Rich77,
I have ordered the same spec RAMS from Crucial (2x1GB), however on installation I get the 'blue screen'. Both sticks work fine independantly, but together there appears a conflict. Did you have to do a BIOS update? Any suggestions from anyone would be helpful.
Thankyou,
Joliraja
I finally got my RAM from Kingston. so far so good, no blue screens.
If you are getting a blue screen i woud surgest a BIOS update if it does not fix it i dont think it will do any harm.
