Measuring temp ~ k series
nick_pan
hey i have a sony vaio pcg - k115m
id really find it useful if i could somehow measure the temp of the system, or cpu using software..
on my desktop, im running `motheboard monitor` which provides a great set of stats relatiing to the motherboard, inc cpu temp! :slight_smile:
however, this useful program does not support the k-series motherboard (or about 90% of any other vaio motherboards)
anyone know of any other programs to display temp?
i tried searching the bios but i found it extremely limited and it basically displays very little info
thanks in advance,
Nick
35 REPLIES 35
profile.country.en_GB.title
kee-lo_
Member
Thats a shame.
GBS
Hi
Ive had my K-115Z for 3 months and so far have not had any of the problems I see mentioned here. I have just downloaded Mobilemeter and the harddrive runs at 46 degrees and the processor at 57 - 59 degrees. This is after 2 hours running, surfing and playing music.
What are the "normal" temperatures, more importantly at what temperature can I anticipate problems?
thanks to Kee-lo and Nick P for their advice.
kee-lo_
Member
No higher than 65 degrees in my opinion.
nick_pan
GBS..you're temps are average though i reckon as kee-lo said, be aware as you approach 65 degrees..
70 and above and the overheating problem this model suffers from could be happening. still you've had it for 3 months, so things sound good :slight_smile:
by the way Kee-lo, using my vacuum cleaner yesterday, sucking hot air out of the back vent dropped my laptops temp to 27 degrees..thats a new personal best for me :smileygrin:
kee-lo_
Member
Lowers temps and gets dirt out at the same time, ingenious Nick.
h.hotz
just try Sandra (SISoftware),
http://www.sisoftware.net
