Hi, everyone,
This is my first post, here.
Can anyone tell me where, in the U.K., I can find a Vaio mains cable (the detachable part with the "Cloverleaf" IEC C5 3-pin plug at one end and the mains plug at the other) with an Indian plug?
The laptop is for a relative in India and it would be easier and more elegant, when using the laptop, if it had a genuine or generic Indian laptop cable and plug, rather than, every time the laptop is plugged-in to the mains, using the British plug with a U.K./Indian adaptor. I can, of course, easily buy a new cable there, but I'd prefer the laptop to be used, straight out of the box, so to speak, instead of having to hunt-down a new one.
India uses the old British 3-pin round plug/socket, as does South Africa, as shown here:
http://www.expansys.com.au/p.aspx?i=103844
http://www.stayonline.com/reference-international-plugs.aspx
I could, but would prefer not to, cut-off the U.K. plug and re-wire with an old British plug, bought here: http://www.powerconnections.co.uk/rewireables_uk_bs546.htm
You'd have thought this would be easy to find, given the large British Indian population, but I'm coming up blank.
Incidentally, although these aren't of any use to me, you can find "Cloverleaf" and 2-pin/”figure-of-eigjht” cables, with European, Australian and US/Japan mains plugs, here: http://www.revealcable.co.uk/acatalog/Clover_IEC_Mains_Cable.html;
http://www.expansys.com/t.aspx?m=306
Thanks.
Hi, Thalamus,
Thanks for the help.
No, the South African cable you've shown has the 2-pin plug (for the laptop) and I need the Indian/South African mains plug (as you've shown) but with the "Cloverleaf"/3-pin plug at the laptop end.
Personally i would just rewire it since the standards are almost identical. 16Amp fuse instead of a 13amp here in the UK.
You probably save you some money to since they probably charge more for the indian style as there is probably less demand.
:smileygrin:
Hi, Thalamus,
I have a Vaio FE41S and everything is correct as far as using it in the U.K. The cable(3) plugs correctly into the adaptor(1) and the adaptor plugs correctly into the Vaio port(2).
The problem is the cable has a built-in U.K. mains plug (naturally, as I bought it in the U.K.) and I want an identical cable, with the "Cloverleaf"-style plug at one end (which plugs in to the adaptor(1)) but the Indian rounded-pin mains plug at the other.
The image you linked to in your earlier post does show the mains plug I'm looking for but the cable has the 2-pin plug at the other end. Maybe this would still work but it would look strange having a port for a 3-pin plug with a 2-pin plug inserted.
I can't understand why it's so difficult to find. After-all, the very cable I'm after must come supplied with all Vaios sold in India. I thought Sony would sell a variety of cables for when it's customers want to use their Vaios abroad. It's much neater than using a wall mains adaptor and would be a nice earner for them.
Thanks.
Are you using the smaller 6amp plug or the larger 16amp plug?
Hi, Matt,
Apparently, the Indian plug is the old-style British plug and most domestic plugs, in India, are the 6 Amp variety.
Although some places say 5 Amps and some, 6 Amps, I could buy the 5 Amp version here and re-wire the cable, but I'd rather not.
My hair is thinning trying to find this damn cable!
Hi, Matt,
