Help! Hardware mailfunction error! GRT896HP
d244541
When I pick up my vaio grt896hp notebook when it's on I get a blue screen with the following message:
HARDWARE MAILFUNCTION
CALL YOUR HARDWARE VENDOR FOR SUPPORT
NMI: PARITY CHECK/MEMORY/PARITY ERROR
***THE SYSTEM HAS HALTED****
And yes, the system has halted.
Another problem which I have is that my screen goes on and off when I move it up or down. Does one or both of the above problems sounds familiar to anyone of you vaio-users?
:cry:
13 REPLIES 13
profile.country.en_GB.title
kee-lo_
Member
Sounds like you need to resit your memory, take it out and put it back in.
d244541
Thank you for your suggestion. Is it easy to do on a notebook?
kee-lo_
Member
Yes, theres a little trap door on the bottom of the notebook.... in there should be the RAM.
Psaila
I'd earth yourself At the start of this operation , Staic is a bad thing at this point .
d244541
Ok, I will try to unstatic myself and open the trap door if I can find it. Thanks everyone. I let you know....
kee-lo_
Member
Good luck
robpaxton
Explorer
Vitally important - unplug the notebook and remove the battery before removing and reseating the memory chips.
kee-lo_
Member
Heh I really ****ed up this time....
robpaxton
Explorer
I've replaced memory and forgotten to remove the battery before - the notebooks survived the operation OK. :wink:
