BIOS setting was changed - Error 603
OPGELOST
profile.country.cs_CZ.title
adamcz001
Bezoeker
The Sony Vaio laptop SVS1512X9EB I ordered a recovery disk. When trying to restore (recovery & maintanance) error message:
"BIOS setting was changed
This recovery media can not be Used for this BIOS setting. Exit VAIO Care (Rescue mode) and change the BIOS setting back to the default.
Error 603 "
How do I switch the BIOS? I suppose now booting from UEFI.
Message was edited by: adamcz001
Tags (4)
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
rich912
Bijdrager
Hi adamcz001,
To enter the BIOS settings press the Assist key when the computer is fully shut down, then press F2 when the Vaio Care | Rescue Mode screen is displayed.
Rich
Go n-éirí an bóthar leat
Bekijk de oplossing in de community in het oorspronkelijke bericht
16 ANTWOORDEN 16
adamcz001
Bezoeker
Magic.... working, thank you very much.
rich912
Bijdrager
You're welcome Adam :-)
profile.country.ro_RO.title
iamcaps
Bezoeker
hi adam , can we talk a bit ? can you give me a skype id or ym or something ? best regards
rich912
Bijdrager
Hi adamcz001,
Rich
iamcaps
Bezoeker
hey rich , i have the same problem using usb memory stick , i had to change from hdd to ssd and i made a recovery usb stick , the problem is that i get that error 603 with bios settings was change bla bla , the problem is that if i change the option in bios from legacy to uefi the usb stick is not working anymore and if i change from uefi to legacy i get error 603 , what should i do please ?
rich912
Bijdrager
Hi iamcaps,
I have no experience of recovering a Windows 8 system but are you by any chance using a USB 3 supported flash drive? I understand that only USB 2 is supported for the recovery process on an external drive.
Rich
iamcaps
Bezoeker
the usb drive is usb2.0 , if i boot from uefi mode i get a bluescreen and tells me something like your pc needs to be repaired bla bla , but its booting from legacy mode but i get that crap with 603 error , any other ideea ? thanks
iamcaps
Bezoeker
model is SVS1512X9EB
iamcaps
Bezoeker
and yes , im using assist button trying to recovery
