Hello Everyone,
Have just aquired first flat screen HD TV - KDL-40HX723.
Superb picture and very pleased.
Has anyone came across this problem?
NON HD transmissions absolutely perfect.
Switch to Ch(s) 50 - 54 the HD versions and every few moments the screen blacks out for probably less than one second, like a frame missing in a movie film.
My aerial supplier suggested that since we went digital the transmitters were boosted and that combined with the fact that I have a mains powered signal booster in the loft (from previous crt tv) I am overloading the tv and that I could bypass the booster and if necessary fit an attenuator. I have bypassed the booster and the problem has all but been eradicated just an ocasional blackout.
Does anyone share this experience and how do I know how much to attenuate the signal ?
When I look at the menu I note that I have 100% signal quality and 95% signal strength.
Any help most welcome.
Many thanks,
David
Simple fix for this one
Your Tv just needs a firmware update to fix this issue. Can either plug it into the web directly or copy the update to USB.. Details on the specific support page for your TV.
Thanks
