pls i'd like to know if my xperia neo v SI 1254-2586 will get ics 4.0.4
i don't want to know the time just yes or no
run Service Menu
http://talk.sonymobile.com/thread/24534
Service info > SIM lock
that would've told you if your phone was/is locked to a network. if you get all 0s it wasn't
Cannot tell. If it's a branded software (operator customized that is) they will have a say on this too. If they say "no", then it will not matter if we say "yes".
So, unfortunately I cannot say yes or no as it's not that easy.
it is not a branded software
Now i updated my mobile manually by using a flashtool by this way i lost my warranty although i have a backup of my original software
not quite
Warranty
From sony mobile developers
http://unlockbootloader.sonymobile.com/instructions
Warning! If you perform this step, you will unlock the boot loader.This may void your warranty and/or any warranty from your operator. If you still want to unlock the boot loader of your phone, enter fastboot.exe -i 0x0fce oem unlock 0xKEY, where KEY is the unlock boot loader key you got in the beginning of this instruction. The boot loader should now be successfully unlocked.
from Sony mobile
Warranty Document
http://www-support-downloads.sonymobile.com/common/warranty_phones_US_12.pdf
Nor does this warranty cover any
failure of the Product due to accident, software or hardware
modification or adjustment, acts of God or damage resulting
from liquid
in other words it "could" void your warranty if something happen to your phone bc of this
run Service Menu
sorry i need to know exactly i lost warranty or no
i flashed my mobile with a sony firmware but not the firmware of my region and what do you think about this thread
http://forum.xda-developers.com/showthread.php?t=1096394
if i applied this to change the customization number of the firmware to the number came with my mobile and then do a repair using sus by this way i'll fix the problem of warranty
just flash the original firmware that came with your phone if you have to take it to a sony repair center to avoid issues
thanks for your response uliwooly
Anytime
