Hi my sp was uploading videos to facebook and youtube without a problem.
All of a sudden facebook videos fail everytime and youtube says unsupported video file???
I connected the phone to my pc and that wont play the videos either?
The videos i record play perfect on my phone though...
Photos not a problem so what have i done?
I must of accidently changed the format that video is recording in..
any ideas as i cant find anything in settings or camera settings and i want to share my holiday videos
Chris
Hi Aimee, Thankyou for your advice which i did try but unfortunatly made no difference.
However, I have cured this problem now...
I realised that my videos were not uploading because i had activated Stamina mode in power management. Since I turned this off my videos are uploading.
So i guess that although stamina mode is supposed to let downloads and uploads continue when the screen goes off, in fact it doesnt let uploads continue.
Problem solved
Thanks
Any Ideas? still cant figure this out
Hi Chris, I'd recommend following these steps:
Open the camera app > Tap the icon in the top left > Select Video Camera > Tap Settings > Select Video Resolution > Change this to VGA.
If you then try to upload a video which was recorded in the VGA resoltion, does this work okay?
What do you think about this forum? Let us know by doing this short survey
Problem solved
Thanks
I'm glad your issue is now resolved
hello!
I've got a similar problem with my phone...
I can't upload my videos on VLC or any other player because of the VGA format!
What can I do to reduce the video??
What is that Stamina mode that you were talking about?
Thanx alot!
