Hi;
Sony people please reply me. My Xperia S is almost one month old, but, my Volome :smileyplus: key is little bit hard to press than Volum :smileyminus:, Volume
is smoother than Volume :smileyplus:. Will it be a problem later on?
Thank you in advance;
zakirox123
Hello: zakirox123
They should both feel the same way.
If the situation worsens I would suggest you send it in for servicing.
(call your local support department as you may be covered by the 1 year warranty)
Best regards
Francis.
ok thank you
i would like to inform this. but, both the volume key's are working in a perfect manner. do i want to give it for service?
hello sony i would like to inform this. but, both the volume key's are working in a perfect manner. do i want to give it for service?
Test it for a wile but if you see it starts to fail then send it in.
You have a 1 year warranty*.
(*some restrictions and conditions apply)
Francis.
hello everyone
I am using Xperia s my phone is having a small problem. Pressing volume up make a little noise( tap tap..) while volume down is queit to press! what should i do?
