Screen protector - to use or not to use? ;-)
Glorifyday
Screen protector - to use or not to use? ๐Ÿ˜‰
My SK15i has a screen protecting film bundled. I haven't try to install it yet.
Do you use it? Does it change the screen contrast or touch reaction? Does it influence the "captive buttons" issue in any way?
camaro322hp
Yes, use a screen protector.  The "scratch resistant" screen is not scratch resistant at all.  I found out the hard way.
22 REPLIES 22
camaro322hp
Pavan_Hyuga
use it. i don't think the sticker coming in default is acting as a proper screen protectr. and make sure you don't put any air bubbles in between it and da screen.:smileyhappy:
i don't say it protects ur screen from scraching b'cause it's scrach resistant, not scrach protector:smileywink:. even i got a little scrach afte 4 weeks. but it repels dust and it's smooth.
Glorifyday
Is there any tutorial on how to put the protector avoiding potential trouble?
Can it be removed afterwards?
Is it true that the bundled protector is directional and there is only one possible position of attaching it?
Pavan_Hyuga
here's how i did it.
1. clean your screen with the tiny cotton cloth supplied with the protector for dust. do this until all the oil marks on ur screen are gone.
2.tear one side of the protector and i applied it from this side
3.paste one side of the protectr first and paste the rest firmly and use the little plastic card suplied with protector to get rid of air bubbles. if any air bubble was created use the plastic card to push it out of the screen.
4. after that tear off the last layer(as i remember there were 3 layers of the protector) which is the one on the top.and GOOD LUCK:smileyhappy:
http://www.wikihow.com/Apply-a-Screen-Protector
http://www.youtube.com/watch?v=ExqpPN5p80E
http://www.ehow.com/how_5236534_attach-protector-phone-air-bubbles.html
http://voices.yahoo.com/applying-screen-protectors-without-air-bubbles-4982534.html
Pavan_Hyuga
screen protectr repels dust particles. so ur screen is protected from the scraches caused from dust. but it won't stand a chance against a heavy scrach. and yes, u can replace protector with a new one when you got many scraches.
Glorifyday
Thanks a lot for this comprehensive help Slightly_smiling_Face
Pavan_Hyuga
u r welcom
james9891
Been using XMP for nearly a year without any screen protector and not even a single scratch
Pavan_Hyuga
my nails give my phn those:smileymischief:
