Can my Xperia S antenna broken ???
If so what can I do ???
Please answer
I'm from Indonesia....
yes i can understand. but you should not worry nothing will happen on its own. if anything happens you can always get it checked from the service centre.
( you can use translate.google.com )
are you facing any problems in network ?
Not at all, but such move slightly
Sorry if my english is not good...
I'm just afraid if it can happen...
As divided into two, because the Xperia S antenna separated by transparent line...
Hopefully understand...
Thank you very much...
I hope this will not happen...
hmm you'r welcome
