Xperia Ray (ST18i) Update 2.3.4 4.0.1.A.0.283
Special Thanx to Jozinek from the XDA Forum
http://forum.xda-developers.com/showthread.php?t=1271512
let me make it simpler
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
Get the ftf files here
get the Flashtool From here
http://forum.xda-developers.com/showthread.php?t=920746
Install it and you will see 5 folders
This is an step by step guide
5.a. Unplug your USB cable from the PCb. Power off your phone and plug the USB into the phone
c. Press back button and keep your finger on button
d. Plug USB cable into your PC whilst holding down the back button on your phone
e. A green LED will appear
f. The process will automatically detect your phone and start flashingg. When "Found at USB/........" appear on flash tool you may release"back button", sit down, relaxand wait.Hope this is helpful to you6. IF the "Start Flashing" message appear everything`s ok if not...repeat. Sitdown and relax (again )
7. When last message appear unplug/plug USB cable
Regards,
Ricardo Rendeiro
Make sure you backup everything
Use this links to download the apk
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkhttp://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
Step by Step videos
hehe..kewl
Improving Battery life
you can also check this video (it's for the X10 but the same is true to most if not all smartphones android/ios)
I just knew it that you would be posting something about the Ray pretty soon.
I thought of doing it but, since you have always done things like this, out of courtesy, I left it to you :smileyhappy::smileyhappy:
Can always depend on you for the links.
From step 5.d, the screen seems to be hard key. Does it work for soft-key of back button on Ray?
with the Ray I think you have to hold the volume key instead, just like if you were using Update Service
i have Android 2.3.3 BuildNr 4.0A.2.368
do i need update ?
