Xperia Ray Fatal Problem! Help!
Ok.............
So, my phone was fine. I plugged it into my comp and the Sony PC Companion says "A new software update"...4.2.B something...I'm guessing that was ICS. And I downloaded it, having heard how awesome it is. Followed all the instructions on the screen. When it gets to "Stage 3" it tells me not to unplug my phone and wait. There's this dotted line showing the pc and the phone. Then, suddenly...that's the end of my phone. Everything went blank. My pc crashed, restarted. I tried to restart my phone. Instead of "Sony Ericsson", it now says "Sony" and then a pic of a phone with an exclamation mark in a triangle appears. I never rooted my phone before. So, yes, my phone is dead. I can't go to a Sony Ericsson Service Center because there isn't one in my country. Now, what do I do???
Nabeel
Do as Veresova said
________________________________________________________________
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
Both the links are same
2 REPLIES 2
Veresova
Nabeel
                  or
