Xperia mini pro x10 won't turn on after battery drain during update
Xperia mini pro x10 won't turn on after battery drain during update.
Hi, the battery of my xperia mini pro got depleted during an update attempt, and since then it won't turn on, charge, nor be recognized by my computer through the USB cable connection. Hence the PC companion won't recognize it as well. It doesn't vibrate or turn any lights on, just gets a little bit hotter when connected for a long period of time. Any ideas on how to recover it?
19 REPLIES 19
not quite, if the LCD stopped working then it won't turn on at all, but if the phone it's on then it should be able to receive calls.
take the battery out -> put it back on -> turn it on and call the phone
Ok, attempted to turn it on (pressed the button until the phone vibrated) but when I called, it is like the phone is off.
and my computer is failing to install an USB MTP driver when the phone is connected to it.
borrow another SIM card and try again
Well, yeah, now it is ringing. Tyvm for ur time and help. Will give the cellphone back to my friend and tell her that I cannot do anything about it.
Until next time!
Anytime, remember you could either
1) send it to Sony Repair Center
or
2) buy a replacement LCD and repair it yourself (it's not that complicated)
Well, I'd like to learn how to replace it then. Lead the way.
this is how
http://www.ifixit.com/Teardown/Sony-Ericsson-Xperia-X10-Mini-E10i-Teardown/3124/1
OK, tyvm.
Anytime, have fun and read the guide few times before you procede Slightly_smiling_Face
