Xperia Arc Update problem
Why i can't still update my xperia arc LT5i to ICS? PCC always encounter an error w/o an explanation.
pls enlighten me. tnxs.
http://forum.xda-developers.com/showthread.php?t=1324703
12 REPLIES 12
do you get the same error with SUS?
can i still update even if my boot loader is unlock?
no, you need to lock your bootloader
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
Uli how?
okay ill try ill keep you posted.. tnx
uli got it. thank you very much for the help ....
did it work? do you have 4.0.4 now?
