Xperia arc data not working anymore
My data has recently stopped working i have repaired the firmware through pc companion and it still isn't working i haven't messed with the settings it just simply stopped working any suggestions?
Cheers
slimshaddy
Hero
you can go to settings > wireless and networks > mobile network > operators
it will search , and make sure the operator has a 3g sign.. i mean there are 2 networks 2g and 3g listed there..
it happened to me also..
it automatically shifted to 2g..
when i selected the 3g , net worked Winking_Face
9 REPLIES 9
settings -> sony ericsson  -> internet settings
who is your carrier/network?>
I done that i'm with t-mobile
Sorted seems to be working now
cheers
I'm glad it's working now, what was the problem? did it worked?
Make sure you backup everything
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
I Just went settings then sony ericsson then my carrier then nothing but eventually the h symbol appered and that was it done sorted! and i have everything backed up mate thanks.
OK cheers mate
anytime
slimshaddy
Hero
