wt19i: "available system update" in taskbar. In pc comanion "system is current". Why ?
Hi.
I have a problem.
In my walkman wt19i on taskbar I have a message "Available system update 4.0.2.a.0.62".
In menu "Phone information >>> Update center" I have this message too.
If I click on this message I have information: "Is only available to install by PC Companion"
Now I connect my wt19i to PC via USB.
PC companion says: "Phone system is current".
What can I do to fix this problem ?
Best Regards
Nabeel
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
both the links are same
13 REPLIES 13
Nabeel
                  or
SEUS detected: "System is current".
My smartphone is working ok...from bought.
In today morning after connect phone to WiFi, I see this notification.
I have only "system update notification" problem...
other works...
Nabeel
try with another pc
turn antivirus/ firewall off
if possible, allow access to pc companion in the list of firewall and antivirus Slightly_smiling_Face
I'm not understand You. Sorry.
My phone and PC working and connect properly...
I have only problem with "update notification" in my phone.
In android taskbar, and update center menu i see text: "system update is available 4.0.2.A.0.62". I dont know why I see this text.
I have current system installed (the same 4.0.2.A.0.62).
ONLY "Notification update" looping in my phone. Why?
Nabeel
ohhh i got you now
do this
settings> applications> manage applications > all> update center > clear data Slightly_smiling_Face
Ok. Im using Your solution and reboot the phone.
After reboot:
I go to "settings>Phone Information>Update center"
If i click on "Update center" program is detect "system update available 4.0.2.A.0.62"...why ?
notification looping now.
(Yesterday in menu "settings>Phone Information>Update center" I see: "Update is not available. You have a current software and applications from Sony Erricson"
Today morning I first have this problem...
Nabeel
is your device rooted ?
no is not rooted. I not install any new apps from yesterday...
Yesterday is working ok, Today is working with problems.
Nabeel
what you can do is either ignore the notification popping up in your mobile
it might be temporary
use the clear data option to get rid of it for some time
or reinstall your phone's software using sus again Slightly_smiling_Face
