wifi connection problem ?
last time i use wifi, everything is fine.
then i connected to my new TV sony 40EX520 to check some its functions (open video, pictures on phone....)
and now when i try to connect wifi, i only can access the local network (LAN) (i can access shared folders )
but when i try to access the Internet, i got a long loading
and then
"Web page not available"
Check to make sure your device has a signal and data connection
What should I do ?
I have restarted my phone twice but it didnt work.
(of course the internet works, because i try a laptop and it works)
Johan
Check what IP address your router gave the phone? It should be a internal address like 192.168.x.x.
If not you'll need to check your router settings, look for DHCP settings in your router and make sure that it's enabled properly.
If problem still remains make sure that your router is using the latest version of it's firmware and then reboot both phone and router and try again.
2 REPLIES 2
Johan
yeah, rebooting the router make it works again
thanks
