did you try force restart??
open back cover push and hold off button untill phone reboot
remove All widgets and then goto camera and goto setting...there is a quick lunch option..turn it off..then put it on lunch
Hey.. I faced the same prob! but solution is... If you will set one of the defualt wallpaper of sony as lock screen wall paper thn you will get the plus sign as well as the widgets.. otherwise setting our pic or any sort of other wall paper wont give such options except date n time widget
