why can not i download via wifi?
hi Slightly_smiling_Face
my experia can browsing everything with smoothly via wifi,,but why can not i download something from android market?
everytime i try to download,there is seem to become download,,but that is not.
thanks a lot.
Sam
Legend
Legend
Given what you have tried up to this point, it may be worth running the update service to try an resolve this:
14 REPLIES 14
santam1
hi....:-D  after downloading the application is it added to your My apps tab...??  .....from the market press the menu button then tap my app...
thanks for your help,,but i mean the download is not running at all.
what must i do to fix this?
thanks
santam1
ok...you mean when you press the download button...it's isn't downloading ....??? its just that loading ......
santam1
try this...        go to setting>application>manage applications then on the download tab search for market/google play (the one you got) then tap on that select..clear data and as well as cache...disconnect your WiFi restart your phone and try to download...and keep us updated....:-D
hi
i  can not found download tab search for market at my manage applications.:smileyconfused:
thanks again
gwhispererz
Hi, goto Settings>Applications>Manage applications>MENU (left hard button)>Filter>All>Market>Uninstall updates.  Then try again.
hi
i really appreciate your help.
i have done your suggest and i try to download again.
i can download and install  BravoSE,,one of GO apps with fast,but i still can not download anything else.
thanks for your help Slightly_smiling_Face
best regards
Sam
Legend
Legend
Based on your original post, are you only downloading via WiFi? If so what is the signal to the router like where you are trying this?
hi
i have try to download via my GSM provider too,and it can not work either.
i use wifi at my home from my PC and my daughter can download everything from market via this wifi to her experia mini pro.
thanks Slightly_smiling_Face
