This happens as soon you press the screen. Is this normal? It looks ugly 😕
NOT PRESSED:
PRESSED:
Oh and there are no OSD buttons on lockscreen.
This is normal. I have the same behavior on the text for time and date in the Xperia Z I use.
Thank you for your feedback regarding this.
Seems Normal .. could you mark any specfics that you find different.. And OSD buttons are not needed in the lock screen (No function)
there's nothing wrong at all, or are you referring to the area were your finger swype? if so, then you can download other lockscreen apps from the play market
Look at the Time. You can see there is a white/grey shadow when i press the screen. It is best when you try yourself and just watch it!
Thanks, it is just a choice of design then
