Video Camera Problem
mikejodhan
Yet again, im here with another problem.
When i record a video, no matter what length, the quality is good, but the fps is like 4........
And it plays far from smooth. But other videos i downloaded from youtube play soooth.
Whats the prob here? I used to work well .
there is another option that worked with some users
backup your SD card on your PC then reformat your SD card and repair your phone with either SUS or PCC
on your PC
1) open any folder -> click on tools -> properties -> view -> show hidden files
2) mount the SD card, go to your SD card, press Ctrl + A then Ctrl C, on your desktop create a new folder, open it, then press CTRL + V
8 REPLIES 8
mikejodhan
im going on a class trip tmrw, and i need to take videos of wildlife :S
I really need help
the easy solution is to downgrade to GB
you could try to reformat your SD card and see if that improves performance
mikejodhan
what??? so i upgraded to ics for a better 'experience', and the only solution is do downgrade to gb??
Is ther any other solution ???
U cant be serious here bro....i think ics is better.
The video player worked good around 3 weeks ago (on ics) , but now, its crapped up.
Murphy_Idek
turn off video stabilizer.
Sam
Legend
Legend
You may also want to run a repair of the firmware to reload the ICS version on the phone as this is not normal behavior of this application.
on your PC
mikejodhan
thank you it worked. But as one problem goes away,another arises. My music doesnt show up again .....
repair your phone with SUS
I'm starting to think that your micro SD card its faulty
