Updating problems on my country?
Is available in Argentina 2.3.4 official update? I have bought a Xperia mini pro (SK17a) a month ago and still have not received the update through PC Companion, so my phone runs android version version 2.3.3.
This worries me because ICS is ready to hit the market and the software on my pcmakes me think I have a limitation with updates
how are you trying to update your phone?
try this on your PC
Update Service (SUS)
10 REPLIES 10
try this on your PC
Thanks, I'm downloading the software that you recommended.
By common sense I tried to update it with PC Companion that comes with the phone.
I will try now to see what happens and then comment.
when you try to update your phone with PCC what happen?
is your phone branded to a network or is it unlocked/SIMfree?
Do not worry, will mark the answer as correct when I have my phone updated. I am charging the battery at 100% to try the update.
My phone is branded to a network and PCC now tells me that my phone is updated
(Remember it's a SK17a and still running version 2.3.3)
ok the problem is your network not your phone or SONY, there are certain networks that do NOT release the updates, you are really behind, you have an option to manually update your phone, thus debranding your phone, in other words it will delete apps made by your network, but you will get the update now.
you care 4 or 5 updates behind, if you want to manually update your phone this is how
Xperia Mini Pro SK17i/a 2.3.4 update 4.0.2.A.0.62
http://talk.sonyericsson.com/thread/30651
it's quite simple, just watch the videos
Well, I just made an attempt to update but I stopped him before beginning. I stoppedbecause I read what you said about my network operator and I got to thinking that would remove the support they give me.
However SEUS told me that my phone was already updated with the latest version, but if it did not work well could overwrite it again, which as I said, I did not try
Thanks for your help:smileygrin:. Later I'll contact my operator and decide what to do with the software.
http://img821.imageshack.us/img821/12/seus.jpg
El mensaje fue editado por: pullman. Resize image
what support are you refering to? if you use SUS or PCC it won't remove anything, if you use Flashtool it will remove the network apps, you can always flash/re-install your network's firmware.
go to settings -> about phone and check the "Build number"
here is a list of updates that you are missing
http://www.ptcrb.com/vendor/complete/view_complete_request_guest.cfm?modelid=19510
Manufacturer:Sony MobileModel #:SK17a (AAD-3880105-BV)Supported Technologies
and Frequency Bands:GSM: 850/900/1800/1900, UMTS FDD: Band I/Band II/Band V
HW VersionSW VersionRequest TypeDate Certified
A4.0.2.A.0.69ECOFeb 27, 2012
A4.0.2.A.0.62ECODec 20, 2011
A4.0.2.A.0.61ECODec 12, 2011
A4.0.2.A.0.58ECOOct 21, 2011
A4.0.2.A.0.42ECOOct 7, 2011
A4.0.1.A.0.283ECOSep 16, 2011
A4.0.1.A.0.266ECOSep 6, 2011
A4.0.A.2.377ECOSep 2, 2011
A4.0.A.2.371ECOAug 24, 2011
A4.0.A.2.368ECOAug 2, 2011
A4.0.A.2.364ECOJul 29, 2011
A4.0.A.2.362ECOJul 29, 2011
A4.0.A.2.335VariantJul 22, 2011
I stoppedbecause I read whatyou said about my network operator and I got to thinking that would remove the support they give me.
I refer to technical support, the help they give me when I have problems or serviceconfiguration. I also refer to the warranty, and they gave me the phone a month ago. (I am using a translator and I hope you understand so clearly what I'm saying)
well, I think I have a few pending updates .. because my phone says its build number is: 4.0.A.2.335
Thank you very much for explaining about FlashTool and re-installing network's firmware
